Hey Guys,
I am trying to separate these sketches in this one dxf file that I downloaded. There are nine sketches within this file.
When I try to manufacture one sketch it shows some tool path but then goes to the next sketch and starts a tool path so that tells me all the sketches are still linked together. I want to have nine separate sketches. My terminology might be incorrect above but I hope you get the gest of what I am trying to do. I am using a Hypertherm 45 xp plasma cutter.
Thanks in advance,
Glenn
Solved by g-andresen. Go to Solution.
