How to select more than one spline curve to split object
chipcoates
chipcoates
I am trying to select two spline curves to split a object into three parts. I can only seem to select one of splines to do this? Is there a way to select more than one spline and then split the object. See attched image for visual.
Thanks in advance.
LMD001
Hello chipcoates,
Selecting multiple splines to split a body is not supported.
You can do this in 2 steps (or more if you would like to use even more splines).
Here is a small Screencast on how to do this: http://autode.sk/1Mvz2K3
You need to reactivate (put the light bulb "on") the consumed sketch after you did step 1, or you will no longer see the other splines.
Another way with 2 splines is to connect them.
Then you can do the Split in one go.
Hope this is helpful to you.
Best regards,
Ludo
chipcoates
Thanks for this, much appreciated 🙂
