How to select line that is over second line.
I'm using a lot of construction lines. It's very useful part of my work.
I've started using Fusion. But i'm going mad when i try select line that is over construction line.
Fusion always choose construction line. So mirroring items by selecting them is impossible.
HughesTooling
Have you tried holding the mouse button down for a second or so, you should get a list to pick from.
Mark Hughes
Owner, Hughes Tooling
Hi, thanks.
That works.
Now it's to improve selection of multiple elements.
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/selecting-items-in-sketch-and-i-think...
once more thank you Mark 🙂
TrippyLighting
If that worked, then please give a Kudos where it's due and mark the answer as "Accept as solution"
done that before.
