@Anonymous
As posted here:
https://forums.autodesk.com/t5/design-validate-document/fusion-360-readme/td-p/4311780
MAC
Uninstalling
Fusion downloaded from Autodesk.com:
1. Click the Launchpad.
2. Find and click on the Remove Autodesk Fusion 360 icon. This starts the Uninstaller.
Clearing remaining program files:
1. Using Finder navigate to /users/<username>/Library/Application Support/Autodesk/.
2. Check for and delete the following folders if they exist:
- Autodesk Fusion 360
- MC3
- FusionDoc 2016
- Synergy
- Neutron
- Neutron Platform
- NINVFUS
- production
- Web Services
- Webdeploy
3. Next, in Finder go to the following folders and remove the listed folders/files:
- /users/<username>/Library/Application Support/Autodesk/Common - If present, delete the Material Library folder.
- /users/<username>/Downloads - If present, delete Fusion 360 Client Downloader.dmg.
- /users/<username>/Library/Caches/com.autodesk.senddump
- /users/<username>/Library/Logs/autodesk.webdeploy.streamer.log
- /users/<username>/Library/Preferences/com.autodesk.fusion360.Autodesk Fusion 360.plist
- /users/<username>/Library/Preferences/com.autodesk.MC3Framework.plist
- /users/<username>/Library/CrashReporter/MaterialLibraryMigrator...plist
-/Library/Application Support/ - If present and empty delete the Autodesk folder.
4. Finally, launch a Terminal window.
5. At the prompt enter open $TMPDIR and press <Enter>.
6. In the Finder window if present, move the following folders to the Trash:
- Autodesk
- Neutron
- protolabs
7. Once done, close Finder, then close Terminal.
Fusion downloaded from the Apple Store:
1. Drag the Fusion 360 icon from the LaunchPad to the trash.
2. Using Finder go to /Users/<username>/Library/Containers.
3. Delete the entry com.autodesk.mas.
4. Close Finder.
Phil Procario Jr.
Owner, Laser & CNC Creations
