How to remove fillet from an imported step file
sfdesign.sachinforge
Message 1 of 12
Greetings of the day!
Could you help me with this problem. I have received a step file and I want to remove all fillets and convert it into sharp edges to do further changes. When I delete the fillet the whole model gets deleted.
Regards Asha
Replies (11)
Message 2 of 12
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @sfdesign.sachinforge, thanks for posting.
I was able to remove the fillets. I think the order of removal made a difference in this case. I've started with the largest ones, then the small two on the "corners". Then by trial and error I removed the rest. Is this the model you had in mind?
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 12
g-andresen
please watch the screencast
and
günther
Message 4 of 12
I saw the screencast but I didn't understand how did the fillet get deleted. Maybe you deleted the larger ones first that's why
Message 5 of 12
Not really. I tried it on my model it is not happening. Could you please send me your mail-id ? I can send the model and you could help me with it.
Message 6 of 12
g-andresen
1. There is no regularity to this process.
First I try to remove several fillets via window selection.
2. If this is not completely successful, I remove the remaining ones individually, whereby the order is also done by trial and error.
günther
Message 7 of 12
TheCADWhisperer
Is your model different than the file that you attached earlier?
Message 8 of 12
yess
Message 9 of 12
TrippyLighting
Then you should share exactly the model you are working with, or if you cannot, at least share a screenshot of it.
On more complex objects this takes some experimentation, and sometimes it does not work at all.
i usually Analyse  a model to see in what order the fillets have been applied. Then I try to remove them in reverse order.
Message 10 of 12
Sure this is the model I am working on. It is a forging model of a lower receiver. I need to delete the fillets because I want to change the draft angle. I have tried all possible ways but I can't delete the fillets. Is there any way. I cannot share the model to maintain data privacy.
Note: This model is an imported step file.
Message 11 of 12
TrippyLighting
I think the fillets on his model are too complex to just delete.
You'll have to experiment with the untrim tool in the surface tab and then re-trim surfaces to get these sharp edges back.
That will be a lot of tedious work, but it can be done.
Message 12 of 12
TheCADWhisperer
Use the imported as reference to remodel from scratch.
You will then have a fully parametric model that should be easy to edit.
