How to remove a section from a solid
games1232002
Observer Observer
Message 1 of 13
games1232002
Observer
Observer
Sorry I am very green to this but I was wondering how can I remove the section in red?
I thought intuitively it's a easy thing to do but for some reason I tried for many hours without success.
Things I have tried so far:
  • Use offset face
  • Use an angle plane
  • Use split body using a box
Can someone help me? Much appreciated.
Replies (12)
Message 2 of 13
Warmingup1953
Can you share your Fusion file?
Message 3 of 13
davebYYPCU
Is that body a converted solid from an STL body?
Extrude the triangle face back to the alignment you want.
If still a Mesh body, make a new body the shape you wish to remove and use Combine > Cut.
Might help...
Message 4 of 13
games1232002
Observer
Observer
Here it is... Hmm everything is so unintuitive after moving to Fusion cloud...
Message 5 of 13
games1232002
Observer
Observer
Yes it is a converted solid from STL file. I had to generate face then convert to mesh.
Message 6 of 13
kacper.suchomski
Hi
The easiest way is to simply model it from scratch.
You'll need two sketches and two extrudes.
Use this file as a reference for measuring dimensions.
It will take you two minutes, and the operation history will be clean and legible.
Kacper Suchomski
Message 7 of 13
TheCADWhisperer
@games1232002
Who created the original stl file?
It has several intersecting faces.
I would use only as reference in creating proper geometry from scratch.
Message 8 of 13
games1232002
Observer
Observer
It was from a friend, I think he might have used chatgpt for it lol
Message 9 of 13
kacper.suchomski
Just model it.
It will take you less time than this conversation, and much less than you've allocated so far.
Kacper Suchomski
Message 10 of 13
games1232002
Observer
Observer
I am really new to this, is there good resources for a quick ramp up?
Message 11 of 13
TheCADWhisperer
@games1232002
It is so poorly done that it is difficult to determine the true Design Intent.
Give it a try from scratch and ask a lot of questions here - you will get real intelligent guidance instead of artificial intelligence hallucinations.
Message 12 of 13
kacper.suchomski
Take a look at this.
You just need to assign real dimensions to the sketch and extrude, which you'll read from your file.
(view in My Videos)
Kacper Suchomski
Message 13 of 13
TrippyLighting
Yep!
Here is a direct link for your convenience:
https://www.autodesk.com/learn/ondemand/collection/self-paced-learning-for-fusion?mktvar004=737433&i...
