How to put vertical dimension between tangent arc and straight edge in drawing mode?
barryQWBNZ
barryQWBNZ
Hi all,
I'm trying to put dimensions on a profile in drawing mode (see picture below). I would like to put a vertical dimension from the bottom (straigth) edge to the tangent of the top arc. How can I do that in drawing mode? I know how to do it in a sketch but that doesn't seem to work in drawing mode.
Thanks in advance!
ClintBrown3D
Hi @barryQWBNZ
If you right-click before you place the 2nd part of the dimension, you are presented with "Snaps", choose Quadrant and select the top of the component.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
barryQWBNZ
Thanks! that worked (see below)
