@Beyondforce wrote:
I opened the file and there wasn't much to see.
@Beyondforce I suggested that he post after each and every sketch, rather than building the Titanic - and the - asking why it won't float.
@Anonymous
1. Your construction line transom width sketch is not fully defined (Note: No lock symbol in browser).
I would create a vertically constrained construction line from the Midpoint to the Origin and then dimension the vertical height.
2. ... construction line cavity radius sketch appears to have been moved off of sketch plane - don't do that.
3. stern sketch - use Equal (=) constraints rather than duplicating dimensions.
4. Sketch curved transom - good.
5. construction line 4ft bow - see #1 (even if the 48 is the only critical dimension - get into the habit of fully defining everything).
6. Notice the white endpoints on hull walls sketch. Try dragging the lines. What behavior do you observe?
Add coincident constraints between the logical endpoints and stern sketch.
@Beyondforce
Actually, there was a lot to see.
Can you imagine where this was going if OP waited till the boat was done to start asking questions why things were falling apart as he edited the design?
