How to place a bearing
Hi All
I rather new to fusion 360 am trying to do a sleadge for my table saw.
What I want to do is to place the bearing so it touches the linear rail as i picture. Cant figure out how to do that also the bearing must be in line there will be bolt and  distances between the bearings.
Hope for some help
Best Regads Henrik
Marco.Takx
Hi @Anonymous,
You can use the Joints to place those bearings in place.
joints
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
davebYYPCU
C =  Axis of rail.
D = Centreline of Bearing to Centreline of Rail
Use midplane (equal) between the two bearings
Both Joint discs at the yellow intersection..
Might help....
chrisplyler
Put a sketch into your bearing component that contains at least one point (plus whatever is necessary to constrain the desired position of that point) such that the point can be used for a joint location.
https://knowledge.autodesk.com/community/screencast/428c2239-fb24-4483-9d2a-daccd73a05d7
etfrench
Why are you not using the linear bearings made for the rail?
ETFrench
