How to obtain values of deflection along the length of a simply supported beam?
I carried out a simulation in which a simply supported beam is acted upon by multiple point loads. I needed the values of deflection, stress, strain etc at different locations along the beam. In Fusion 360, the simulation the results display the maximum and minimum values. How to obtain the results at any desired point along the length of the beam?
Ex. A beam of 100 mm length, i need the results at locations at 2,4,6 .. 100 mm.
henderh
Apologies for the super late reply.  This has been asked again this newer post:
https://forums.autodesk.com/t5/fusion-360-design-validate/how-to-obtain-values-of-deflection-along-t...
You can use our point probe tool in the Inspect Panel in the Results tab to specify result values via specific (x,y,z) coordinates.
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
