How to move Sketch XY in model Z direction
I finished a sketch using a construction plane XY
Now in model I want to move sketch / construction plane in Z direction.
Used command model/modify/move
saying to move sketch entities
It doesn't work
Is there someone who can tell how it should work??
davebYYPCU
Quick answer is to create a parallel plane in Z direction, new sketch, and project (the required) to the new sketch there.
Either way you can't move the sketch plane of XY, Origin.
Having made a second sketch, Copy Paste will work.
Might help
masureb
If you go to the direct environment you can move any entity in the 3 direction (Plane, Canevas and Sketch, etc).
To do so, right click on the browser tree and say "Do not Capture Design History" or Create a Base Feature.
Hope it helps.
-Bertrand
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
TheCADWhisperer
Roll back in history prior to the sketch.
Create desired workplane.
Roll forward and right click on the sketch to Redefine Sketch Plane and select the new plane.
