How to model bend coil?
travis.designer.vn
travis.designer.vn
Hi
I model this coil in Rhino.
I try modeling in Fusion 360. First I use Coil feature then I use Pipe tool in Form mode.
Then I use Edit form/ use Soft Modification/ Move up
But it look not good. Direction of circle should be into center. Need advice to model better.
Thank
Travis
TrippyLighting
Just use the term “bend coil” and google. I just did and there are many tutorials showing usually the same technique.
TheCADWhisperer
travis.designer.vn
Hi @TheCADWhisperer
I upload file.
