How to Model a Thread Through A Chamfer?
I'm a student learning Fusion 360 for CAD/CAM work.
I'm modelling one of my school assignments, a manual turned spindle body.  I'm having trouble modeling a 1-14 UNC thread past a chamfer.
I sketched the entire profile, then revolved it, and modeled the thread on the diameter.  The thread does not penetrate through the chamfer, and I cannot add the chamfer faces to the thread modeling face.  I tried removing the chamfer from the sketch, modeling the thread, and then applying the chamfer, but this does not work either.
Any ideas?
Model file links:
http://a360.co/2fWJwqH
http://a360.co/2za7kjk
Brian
JDMather
@Anonymous wrote:
Any ideas?
Export your *.f3d file and attach it here and I will create video on solution using your model.
Hello all,
Thanks for the replies.
I tried the suggestions shown above. Creating a custom thread profile and
sweeping the helix worked ...but it lost the thread spec (1-14 UNC 2B) that
was available to me using the 'thread' command, and was therefore less
accurate. It was also more work.
The second work-around involving disabling and shuffling around the thread
and chamfer commands has ceased to work.
JDMather,
I believe I reset the file permission to allow you to access the model:
http://a360.co/2yhWuJU
etfrench
Here's one way to do this:
ETFrench
Whoops, I'm not sure why my last message isn't displaying.
Either way, I misunderstood the request to upload my file.  Here's the requested .f3d file.
https://drive.google.com/open?id=0B057xHnrRpk7Tl9BeVJUd3BzRTQ
Thanks again!
etfrench,
I finally had a chance to sit down and watch your video, and had to chuckle at how clever your solution is!  Very smart and maintains the thread spec too ....even if it's still a lot of work.  Thanks!
I hope Autodesk can debug the thread modeling command eventually.
