How to model a hex part that is turned/chamfered down to a cylinder?
mgorchard
mgorchard
Sorry if this is really basic, I haven't been using Fusion 360 for very long and I was unable to find a solution but I may be using incorrect search terms.
I am trying to replicate the photographed part, and I have included a render of where the model is at so far. I have been unable to figure out a way to represent the process of turning a taper on the end of a hex for chamfering purposes. Any assistance would be appreciated.
davebYYPCU
Use Revolve > Cut,
make a sketch above your cylinder, with the inclined line at the correct angle.  Close the profile high enough to clear over the hex edge.
SaeedHamza
Check this screencast please
Kind regards, Saeed
Saeed Hamza
TrippyLighting
The cylindrical part is created on a lathe and that's how modeling should be approached. This is not a loft, but a revolve.
SaeedHamza
@TrippyLighting you are right, it's just as @davebYYPCU explained it
revolve is the solution
I should have thought more about it 😛
Saeed Hamza
mgorchard
Guys, perfect. Thanks so much. I had tried loft and it kinda worked but didn't feel quite right, the revolve -> cut makes more sense to me as it's basically a turning operation in itself.
