How to make these spokes flow together?
klcjr89
klcjr89
Hello, I am trying to figure out how to make these spokes flow together. I have taken the help given to me here a couple weeks ago (much appreciated!) and have come up with the design and shape of the spokes that I was after. However, I am stumped on how to go about filling in the missing gaps so they flow nicely together.
Attached is a screenshot with red arrows indicating the missing areas I need to accomplish and flow together nicely. The dark areas are concave and the light areas are convex.
Attached is the .f3d file if you need to see how I got to this point; hoping I don't have to scrap/abandon everything and redesign. It took a while measuring and getting the exact profiles I was after!
I appreciate any help 🙂
TrippyLighting
As it was @cekuhnen who suggested this method, maybe he can weigh in 😉
cekuhnen
@klcjr89 @TrippyLighting
all you need to do is make more 3d blend curves
then loft the 3 areas
finally fill the center top opening with a patch surface
here:
https://drive.google.com/file/d/0Byzv_NlyKp_2T3lsQWpTNGZuWDg/view
NOTE:
the loft code is in fusion and inventor unable to deal with rail surfaces blending properly so you
have to make a 3d sketch to create 3d rail curves.
but be aware of as you can see in the end of the video that the sketch engine has bugs and you can easily run into issues
You will see the issue of dimension problems happen after I added G2 to the splines and start
adding dimensions at around min 4:10.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
SaeedHamza
Ever since your post 2 weeks ago, I've been trying to achieve this, and this is the closest I got, I hope it's good enough
This is a rendered picture, and the file is attached if you want to check the time line and my workflow
If you can't follow the steps in my file, please let me know and I'll make you a screencast
Regards
Saeed
Saeed Hamza
SaeedHamza
Saeed Hamza
cekuhnen
another approach just with G1 because with the crippled and bugged sketch engine it is pointless to work with G2 for 3d sketches
Claas Kuhnen
