How to make the body with thicknees?
6 REPLIES 6
Hrvoje-
527 Views, 6 Replies
Hrvoje-
HI!
I have the body defined with the mesh. Now I want to give the thicknes of 0,2 mm to this mesh and obtain the shell. I tryed to do that but without the success.
How to do this?
I included the file with the mesh.
Thank you for the help. Smiley Happy
Kind regards,
Hrvoje 🙂
HI!
How to do this?
Kind regards,
Hrvoje 🙂
Tags (1)
6 REPLIES 6
Phil.E
in reply to: Hrvoje-
Phil.E
Currently there is no way to do this with Fusion 360 alone.
The Mesh > Brep converter cannot convert it because of too many triangles.
Do you have a way to make this a quad based obj?
Phil Eichmiller
Software Engineer
Quality Assurance
Phil Eichmiller
Software Engineer
Quality Assurance
Hrvoje-
in reply to: Phil.E
Hrvoje-
At the moment I don't know. I will see if I can make quad based object. The ship's form is made in DelftShip software.
(What is the  meaning of "Brep"?)
Thank you for the advice.
Kind regards,
Hrvoje 🙂
Kind regards,
Hrvoje 🙂
PhilProcarioJr
PhilProcarioJr
@Hrvoje-
B-rep meaning:
https://en.wikipedia.org/wiki/Boundary_representation
As far as converting your mesh into quads try Momento. I think for what your doing it will work fine.
https://memento.autodesk.com/about
Phil Procario Jr.
Owner, Laser & CNC Creations
@Hrvoje-
B-rep meaning:
Phil Procario Jr.
PhilProcarioJr
@Hrvoje-
Momento wont work for what your trying to do, I just tried. You can convert it and get it into Fusion but you can't thicken the resulting body. I will try another trick when I get home.
Phil Procario Jr.
@Hrvoje-
Phil Procario Jr.
Hrvoje-
in reply to: PhilProcarioJr
Hrvoje-
Thank you Phil for your kindness and efforts to help me.
I bypassed the problem in the following way: I exported from DelftShip the hull's form in the DXF data file. Then imported these data into AutoCAD. The sections are defined with 3D polylines with a lot of control points. Then I made (by hand) the same sections using spline tool. It is possible to obtain the same line form with 10 spline control points like a line form defined with 500 3D polylines control points. The only problem is the fact that I need to use some time to do the job. When finished I will show the result here.
Kind regards,
Hrvoje 🙂
Kind regards,
Hrvoje 🙂
Phil.E
Phil.E
@Hrvoje-
I'm glad you found a way to achieve your model. I'm looking forward to see your creation!
Phil Eichmiller
Software Engineer
Quality Assurance
@Hrvoje-
Phil Eichmiller
Software Engineer
Quality Assurance
