There still is a lot of missing information so I will let you follow my method, if it suits, and use your dimensions. Let me know if you need help on your model. If you do, do not forget to attach your attempt.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
