How to make a paper fan in fusion 360?!
k1
Observer Observer
Message 1 of 9
k1
Observer
Observer
Hi, I am trying to model a realistic paper fan in Fusion 360. Having great trouble so any help is much appreciated! Please see the attached reference photos 🙂
Replies (8)
Message 2 of 9
TheCADWhisperer
@k1
Can you File>Export your *.f3d file of your attempt to your local drive and then Attach it here to a Reply?
It is more complex than might be initially thought if true replication is desired.
Message 3 of 9
k1
Observer
Observer
Hi TheCADWhisperer, OMG this is exactly what I want! I am slightly unsure what you mean in your first message but I agree it seemed more complex than it should be. Any chance you could please share this file with me? Thank you so much for your help!!
Message 4 of 9
TheCADWhisperer
@k1
Message 5 of 9
k1
Observer
Observer
Hi TheCADWhisperer, Thank you for your reply. My attempt is of no help to anyone, I was hoping you could send me your file. The fan also has to be realistic as if it was made from paper and being opened, like the last attached photo. It can be done in a 3D animation programme so must be doable here. I don't need it animated but needs to be how it would be once opened in an animation around the stick in the first two photos. Thank you
Message 6 of 9
TheCADWhisperer
@k1
I recommend that you start with the Tutorials.
You will first want to learn how to create a fully defined sketch.
Once you have gone through the Tutorials you will then be able to follow the file (or step-by-step) instructions that I give you.
Message 7 of 9
k1
Observer
Observer
Hi TheCADWhispererThank you and please can you provide the step-by-step instructions so I can take a look?
If anyone else has some additional advice or help, please let me know!
Message 8 of 9
TheCADWhisperer
Step 1. Sketch a circle.
Message 9 of 9
TheCADWhisperer
@k1
Attach your progress file here when you have the circle, and 3 lines completed for next set of steps.
