How to make a fillet go the right direction?
michael55SE4
Message 1 of 15
michael55SE4
It seems like different edges will randomly project a fillet in different directions.  How in the world can I control it?
The current problem is a revolved object with tabs sticking out that were created from a circular pattern.  Of the 3 tabs, two fillet in the right direction one would expect, and the other goes the other way.  I've spent hours trying to find a solution, but no luck.
Any hints what I've done wrong here?  This is driving me nuts.  Note that this is on a single body.
Thanks!
Replies (14)
Message 2 of 15
veeramani4
hi,
you go ruler fillet
select input feature or face
then select against future from scope option ( I think your future is revolve)
click ok
ok
all the best
Message 3 of 15
michael55SE4
You'd think that would work, but it doesn't appear to do anything at all.  I've never used it before, but I can't figure out why a regular fillet works on two of the tabs and not on the 3rd.
Message 4 of 15
jeff_strater
Hi @michael55SE4,
We'd have to see the model to be certain.  When you say "goes the wrong direction", I assume you mean concave vs. convex, is that correct?  If so, then the only way that I know of for fillet to get that backwards is if the edge being filleted is not really merged with the body.  That is, the body may look like this is a concave edge, and therefore should produce a convex filet, but if some failure or mis-alignment has caused the body not to be merged at this point, that edge can actually be convex, and produce a convex fillet.
Please share the model and some screen captures of what you are seeing, and we can check it out.
Jeff
Jeff Strater
Engineering Director
Message 5 of 15
veeramani4
only two option one is you chose side by side it means at a time you can do one axis and select next axis's
second one depend ruler fillet based on future it means extrude or revolve like this after you select fillet then you select future from history line
Message 6 of 15
michael55SE4
Thanks for your help!
I attached a screencast of the problem to this post that shows what's going on in detail.
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/screencast/Main/Details/5d1d6dd...
To repeat what's on the video, the tabs are all identical.  The 15mm fillet on the left is what I want, but when I try to configure a 15mm fillet on the right the direction is down for some reason, not up like on the left.
Message 7 of 15
jeff_strater
Yes, this is almost certainly a case where the bodies are not joined.  Can you show an image of your browser, with the Bodies folder expanded.  Even better, if you can share the model here, it will be much quicker to diagnose what you are seeing.
Jeff Strater
Message 8 of 15
jeff_strater
Forget the request for the screen image.  I can see in the video that there is only one body there.  But, we do need to see the model to figure out what is going on.  So, if you could share it with me, it would help us diagnose this.
Jeff
Jeff Strater
Message 9 of 15
michael55SE4
There's only one body, so that can't be the problem.
I'd be happy to share the file;  how do I do that since its in the cloud?
Message 10 of 15
jeff_strater
Thanks.  Here are directions for sharing:  How-to-share-a-Fusion-360-design.
I tend to just use the local Export command, and save to my computer, choose type "archive files *.f3d", and upload the file here.  There are other options, as well, in that article
Jeff
Jeff Strater
Message 11 of 15
michael55SE4
Here's a link to the design:
http://a360.co/2z7mvMK
Message 12 of 15
lichtzeichenanlage
You can either right click in the browser tree (top level) and perform an export or you can share a link (unless it's in the cloud) by right click the design in the data panel and choose "Share Public LInk". Don't forget to enable "Share the latest version with anyone using this public link" and "Allow item to be downloaded"
Message 13 of 15
jeff_strater
So, I understand why the fillet is being applied like it is.  The edge of the tab does not touch the dome.  I colored one face red to highlight the difference:
Zooming in:
I need to look closer at your sketch, but I suspect some asymmetry there is the source of the problem.
Jeff
Jeff Strater
Message 14 of 15
michael55SE4
Thank you so much for looking at this.  I can see why the model as it is would cause the fillet.  Apparently when I extruded that one tab I didn't pick up all of the material fitting into the interior of the dome.
I really appreciate your help.
Message 15 of 15
jeff_strater
Hi @michael55SE4,
Here is an unfortunately long video (with audio) explaining my struggles to get this right.  I think I can fix this, but is was surprisingly hard.  The final moral of the story is to over-select the profiles, and this will make sure that you don't have this problem.  Also, making sure you have things correctly horizontal/vertical also helps...
Jeff
Jeff Strater
