how to make a 3d Model from a Line Sketch dxf from rstab
BreadmakerHai
Observer Observer
BreadmakerHai
Observer
Observer
Hello everyone,
I created a construction in rstab and exported it as dxf so I can open it in Fusion 360 to make a stl to 3d print it.
When I import the dxf to Fusion the construction just consists of lines.
Can i create a solid body out of this line sketch?
wersy
Use "Pipe"
davebYYPCU
Can i create a solid body out of this line sketch?  Yes.
there are no free lunches with imported data.
the blue lines and white dots need work for Fusion to use it efficiently.
Might help….
Warmingup1953
Can you share the Fusion 360 File? What does each line segment represent in your final outcome?... A cut and welded straight steel pipe? More details, please.
