How to / joint ??
How to / joint ??
How to / joint ??
How to join element with midpoint of the hole? (triangle point)
Now is jumping from front and bottom side of a hole
HI @Anonymous
When you hover your mouse over the hole hold down the Command key on Mac or Window key and then move your mouse to the center of the hole and click on it to select the center.
Here is a good Autodesk Fusion 360 video on joints you may find helpful too.
https://www.youtube.com/watch?v=2c67o-bXMhk
Hope that helps. If not attach a copy of your model and I can show you how.
thx 🙂
it works
but - when there is a clear view of the background - do not
The point must be displayed on a some wall background
TM
@Anonymous
Glad you got it to work.
"but - when there is a clear view of the background - do not
The point must be displayed on a some wall background"
Yeah, like this.
works
thx
