How to join two pipes
lauronS2NZY
Message 1 of 8
lauronS2NZY
I am trying to join these two round pipe sections with a tapered connection 3mm wall thickness. Tried a loft, but could not seem to make it work.
Replies (7)
Message 2 of 8
TheCADWhisperer
@lauronS2NZY
I would use Loft, or better yet, Revolve...
Example files illustrating both techniques Attached.
Message 3 of 8
davebYYPCU
Checked the file - now.  You are working too hard.
One circle, modified Extrude1, Chamfer, Extrude2 and Shell.
Hollow loft is not an available option in the Loft command.
Previously I said,
Loft the outside (all) profiles so as to make a lofted joining Rod / Bar.
Shell the Rod to become a Tube / Pipe.  Alternative is to create a second Loft with inside profiles, as Loft > cut.
Might help…..
Message 4 of 8
RufusToad
 Hi, Can you help me understand why the error message accrues when trying to Loft? I get the revolve which works but the file he has shows an error when trying to loft? What is the continuity condition in this example?
Message 5 of 8
davebYYPCU
Using the smooth loft file,
The profiles selected for the Loft, must be the faces of the extruded bodies.
The conditional options are found here. (Connected, Tangent and Curvature - drop down menu)
If selecting the sketch circles, these conditions are unavailable.
Might help....
Message 6 of 8
RufusToad
I think I am missing something as well?
Message 7 of 8
TheCADWhisperer
@RufusToad
Cannot Loft between rings (unless Surface Loft, but that is also circles) - selection must be end face of solid cylinders.
Shell the wall thickness after loft.
Go back and examine the examples that I Attached earlier.
Do you see any Loft between rings?
Message 8 of 8
g-andresen
take a look
(view in My Videos)
Note: The use of the shell tool guarantees a consistent wall thickness.
günther
