How to Join a multi-segment line
tsopkow_rfs
tsopkow_rfs
I have a sketch that consists of multiple line segments to make a sweep path for a piping design, See attached.  The sketch was made using the line tool and creating a path with square corners.  The fillet tools was then used to round the corners.  How do I join all the segments together so that I can use the inspect tool to determine the length of this line?  The end goal is to detemine the lenght of straight pipe required to make this pipe design.
jhackney1972
If the line will work as you path, you do not need to joint it together to get the length.  The video will explain the process.
John Hackney, Retired
laughingcreek
just double clicking on the line so all segments are selected will show the total length at the bottom right.-
tsopkow_rfs
Thank you both for your replys.  Both options work and give the same result, however laughingcreek's method for this situation is simpler.
