How to join 2 DXF files to extrude into one solid?
sg20042000
Observer Observer
sg20042000
Observer
Observer
I am a newbie, and I am trying to join these 2 DXF files to create one solid. Itried to join but I cannot align them so I can extrude into one solid curve part. Any help would be appreciated. I have attached the 2 files. Thanks.
CGBenner
@sg20042000
Welcome to the Community!  Can you tell us in what software you are trying to join these dxf files?
Chris Benner
sg20042000
Observer
Observer
Autodesk Fusion for personal use
##- Please type your reply above this line -#
johnsonshiue
Hi! I took a quick look at the two dxf files. Each contains a closed loop profile. I think you would like to use the smaller profile to sweep along a path in the bigger profile. The geometry is relatively simple. I suggest you measure the geometry and recreate it using sketch commands. Then constrain and dimension properly. It might be quicker than relocating the sketch geometry.
Here is a solution by create a boundary patch from the smaller profile (see attached f3d file). Then relocate it to the bigger profile. As you can see, there are quite a few steps to make it happen. I would simply recreate it at the start of the path.
Many thanks!
Software Test Engineer
Drewpan
Another way might be to create a third sketch that you intend on being the extrusion profile and
then Project only the geometry you need to create the enclosed shape. Then use THAT sketch to
do the extrusion.
Cheers
Andrew
