How to insert a zip 3D model
I need to make a sock on fusion 360 but it is turning out to be impossible to make it. However, there are other 3D models of socks that I can download but they’re zip files or other files that cannot be opened on fusion 360. Is there a way to open it or convert the file?
JDMather
Unzip the file.
If running on a Window OS, simply right click on the *.zip file and select Extract All.
You should now have a folder with a usable geometry file.
Someone will be along shortly and explain what to do if running on a Mac OS.
If you can't figure it out - Attach your *.zip file here.
