How to import/export appearance library
Ezekiel12
Ezekiel12
how can I export from Fusion or import to fusion autodesk appearance library (for example with existing lbirary from Inventor...)
How to do it?
Thx
Matt
jhackney1972
Inventor .adsk libraries are not compatible with Fusion 360.  If you want to import or create Fusion 360 appearance libraries you will find the commands under Tools > Material Browser then follow the screen capture below.  Be sure you are on the right tab at the top, Physical or Appearance.
John Hackney, Retired
