How to have Projected Features Move Later in the Timeline
I think my method of working in projects is flawed as I continue to fight myself as a project progresses. Hopefully I can explain a general case that continues to cause me trouble.
- You start a project with 1 component and you activate that, draw a sketch, and create a body. Call this component A
- You insert a component and place it where you think it should be. Call this component B
- Component B mounts onto Component A so you create a new sketch on the face of Component A and project Component B's mounting hole locations.
- You then create a cut in Component A's body so you can mount B onto A
- You go about the rest of the project adding other components and features.
- I find that I need to move Component B so I move the component. At this point the mounting hole locations created in step 3 are "fixed" to the location of Component B at that earlier time. If I go into that sketch to edit it it shows the old location of component B and not the new location.
So how to you use the project command so that it is referenced to the component location and whatever was projected will move along with the component? Maybe my line of thinking is "screwed up" but it seems to me what I'm after should be the default way of things working. Or you should at least be given the option of saying fix the project to that point in time OR have the projection move if the component moves??
I would love to hear how I'm doing things incorrectly or at least a way to implement what I'm after. I often create projects with multiple components and need to play around with their positions so this is impacting me immensely.
Thanks in advance for any helpful suggestions or links to ways to accomplish what I want!
