How to get to sculpt environment
jemspak7ZM7K
Message 1 of 17
jemspak7ZM7K
The lesson called "Import and Export" walks you through uploading a generic file. The voice over says that the default environment is "SCULPT" but I can't find that option anywhere, nor the "Create Form" or "Create Model" that showed up in other answers (though one was from 3 years ago). So if you link to that old answer I will be even more frustrated with this. This is the 2nd time in 2 lessons that the bloody thing does NOT duplicate the behavior I see on my machine and it's really freaking frustrating to have to search for answers EVERY TIME.
Anyhow, this is what my screen shows under various menus.
This interface is not impressing me so far, Autodesk. Users shouldn't have to hunt around for stuff that you put in your videos.
Screen Shot 2021-01-01 at 5.04.42 PM.pngScreen Shot 2021-01-01 at 5.04.33 PM.pngScreen Shot 2021-01-01 at 5.04.25 PM.pngScreen Shot 2021-01-01 at 5.04.18 PM.png
Replies (16)
Message 2 of 17
TheCADWhisperer
The interface has changed - you are probably watching an old video.
What is the link?
Message 3 of 17
jemspak7ZM7K
this was the list of vids. More important, how do I get to the sculpt environment?
https://academy.autodesk.com/software/fusion-360
Message 4 of 17
davebYYPCU
Step 1, Capture Design History - Timeline - must he turned on.
The menus change and in the Solid area, Create > Create Form will be 3 from the top of the menu.
Might help.....
Message 5 of 17
TheCADWhisperer
Rather than a list - can you specify exactly which one?
Message 6 of 17
jemspak7ZM7K
I can't link direct but it's Video #5, import and export.
Message 7 of 17
jemspak7ZM7K
How do I turn the timeline on? Where is it in the menus?
Message 8 of 17
g-andresen
here
günther
Message 9 of 17
jemspak7ZM7K
OK I found that, bu tI still can't for the life of me figure out how to get to "sculpt" and then (per the video) to "Patch"
Message 10 of 17
TheCADWhisperer
@jemspak7ZM7K wrote:
.... and then (per the video) to "Patch"
From the image that you attached in original problem statement...
These tools are now on the Surfaces tab.
You might have an easier time going through those older videos by first going through these >>
Message 11 of 17
jemspak7ZM7K
Thanks it wasn't clear to me they meant that option since in the video it's in the box to the left where I have "DESIGN". So that is the same "Patch environment" whatever that means, they are referring to, yes?  And what about the "sculpt"? I still can't see that anyplace, or is it hidden somewhere? This whole thing is really confusing at best.
Message 12 of 17
jemspak7ZM7K
Thanks for pointing that out, bu tI should tell you as a relatively non techie user the idea that I have to constantly monitor updates and figure out on my own that the videos presented there -- with NO explanation that they might be out of date -- is off-putting, to say the least.
It's like, "Hey, I am sure all the users are psychics" method of software development/ rollout. This stuff is NOT intuitive to 99% of the population.
Message 13 of 17
TheCADWhisperer
I have to constantly monitor updates....
Welcome to a changing “cloud-based” world.
Fusion is updated every 6 to 8 weeks - but once you get over the initial hurdles - it is still glacially slow in reaching where we were in other CAD programs a decade ago.  These UI changes have brought it more in line with mature CAD programs.
Message 14 of 17
jemspak7ZM7K
If this is slow then it strikes me as not worth using at all... there's literally no point in learning to use it, since it will change on a dime. Every six to eight weeks? That basically makes the thing entirely useless!
ETA: sorry my frustration with this stuff is starting to get to me. But really, you can't muck about with UI all the freaking time with something like this, which is non intuitive and technical, it only makes it *harder* to learn to use it. I can't think of a better way to convince people that CAD isn't for them.
Message 15 of 17
davebYYPCU
If your still here, (I am learning to capture menus)
Majority of changes have been to improve, not confuse.
Might help.
Message 16 of 17
asif.ahmed.cr7
Thanks , It helped me
Message 17 of 17
shahriarsifat1802164
The patch is on the surface portion.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
