How to for spirals
How to for spirals
oliver.luebcke2
Observer Observer
How to for spirals
oliver.luebcke2
Observer
Observer
How are 6 spirals next to each other constructed around a cylinder?
The spiral has two turns. I want to rotate the start and end point by 60° each. But I do not know how.
Thanks for your help.
HughesTooling
Circular Pattern should work.
Mark Hughes
Owner, Hughes Tooling
oliver.luebcke2
Observer
Observer
I can't select the spiral unfortunately. What am I doing wrong?
Sorry, I'm a beginner but am trying to learn...
HughesTooling
If you created it using a coil then set the type to Features and select the coil from the timeline. If you're still stuck, export your design as an f3d and attach.
Mark Hughes
Ajay_Kumar_Reddy
Hey @oliver.luebcke2 ,
Adding to @HughesTooling
1. You can do the 6 instances by using the pattern.
2. coming to the 60-degree thing I did created a sketch and extruded it.
see the attached model.
HughesTooling
@Ajay_Kumar_Reddy  Not sure you've understood.
Pretty sure @oliver.luebcke2  is trying to make a 6 start thread type of feature like this. File's attached.
Mark Hughes
oliver.luebcke2
Observer
Observer
I got it!! 🙂
Thanks to all of you! At first I couldn't reach the axis! But now I got it!
