How to find where design is saved to?
I have a design open that I thought I saved to a particular folder, but I'm not seeing it in the data panel.
I can't find where it got saved to, in order to move it to the place I originally intended.
Hovering over the tab for the design shows the project name and branch, but no folder or "path" info.
I know that I can use the search feature in the data panel for the design name, but this also gives no information about which folder the design exists in.
Is there any way at all to tell what folder this is in?
whittakerdw
You can go to the top of the data panel and press the refresh button while inside the folder you saved the part to. And if it was a larger part it may take a few seconds to save it. In the bottom of the data panel there will be a bar that says upload progress if this is the case.
jeff_strater
This is kinda kludgy, but it is a workflow I use in Fusion, Word, and many other programs when I've lost a file.  I just use Save As.  This brings up a dialog that shows the design's current location, including folder hierarchy...
Jeff Strater
Engineering Director
