How to fill in lines?
jamesliu87878
jamesliu87878
(Complete Beginner) How do I fill in between lines to create a solid shape? I've tried searching everywhere but just can't find an answer
I'm trying to fill in the space between the blue lines. All of the dots are connected.
Thanks.
jeff_strater
we would need to see the design to be certain, can you share it here?  One first check:  In the sketch, do you have "Show Profile" turned on?
Jeff Strater
Engineering Director
jamesliu87878
I've got show profile turned on and all the other options are the same as the image above except for snap, which is turned on.
I tried generating a link but all it shows is a single portion of the design and nothing else
There's not much to share anyways because currently it's only a 2d image on a canvas and a sketch of some lines over it. But I attached a copy of the design.
jeff_strater
Thanks for the design.  The problem is in the upper right corner - you have a few small curves which are construction curves.  Zoom in, make those "normal", and things should be OK
Jeff Strater
HughesTooling
For some reason you have a couple of curves set to construction. Select them and press X to change to normal and you get a profile.
Mark Hughes
Owner, Hughes Tooling
jamesliu87878
Ah ok,
Thanks!
