How to fill in an irregular body
stef_michielshotmail
Observer Observer
Observer
Observer
Hi I have this 3d model of a IMOCA 60 and I want to print it
In the software of the 3d printer the hull was filled with holes. (3d printer isn't mine)
So I wanted to fill in the entire body so that the 3d printer software could do the rest... (my friend said that it would work if it was completely solid)
But I have ran into a lot of problems, like not being able to fill in holes that aren't in one flat plane and such.
And even then I am afraid that if I manage to get rid of the holes, the BOUNDARY FILL won't let me fill in the boat because it is so irregular.
Thank you in advance!
Stef
I am very new to this, and the model isn't completely mine.
dsouzasujay
Hi @stef_michielshotmail ,
The attached design had lot of open surface ends.
When ever you see an open surface, you can create a new surface and stitch them, when there are no more gaps.The final output will be BRep(Solid).
I have attached the final solid BRep design for your reference.
Note: There are multiple bodies, you need to either combine the bodies or remove them(Remove if its not a part of 3D Print)
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Observer
Observer
Thanks a lot!
So if I understand you correctly: If the body has no openings, then it will be considered a solid?
Stef
dsouzasujay
Thats right.
For example, The below design is a surface.
  • In the browser if you see this icon Screenshot 2021-04-09 at 6.14.59 PM.png then its a surface.
  • This icon Screenshot 2021-04-09 at 5.51.30 PM.png means its a solid body
When you see a surface body, select all the surfaces and select 'Stitch' command.
The Red edges shows open ended, Green edges shows the 2 surfaces that can be stitched.
If you properly fill all the open ended edges and stitch them then it will be solid.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
