How to fill in an empty mesh ?
Le_Bear
Le_Bear
I have this STL file, which is just a surface. Fusion tells me it has a NEGATIVE mass.
So, I get an error on basically each operation I want to do on it. What could be the proper way (besides re-creating a solid from a section sketch) to fill_in this empty mesh? Could be useful to know for meshes more complexes than this one.
Bernard Grosperrin
Autodesk Certified Instructor
FaceBook Group | Forum | YouTube
Group Network Leader
HughesTooling
Switch to the Mesh tab\workspace, Modify and Reverse Normal will fix it.
Mark
Mark Hughes
Owner, Hughes Tooling
Le_Bear
Thank you! I had no idea that was what this command was doing. Now it makes sense. Kinda.... 🙂
Bernard Grosperrin
