How to extrude from multiple faces on a body. Or to avoid this problem, how do you combine faces of a body so it is one uniform workpiece?
jeppe489BC
Observer Observer
jeppe489BC
Observer
Observer
Like title says, I am trying to extrude this sketch from the curved body, but I get the error that it is outside the face boundary. How can I fix this? appreciated very much. Thank you in advance! Pic attached of body and sketch
davebYYPCU
No file, we guess,
extrude into the body, and depending on your intent, you can cut and trim sections.
Might help....
jeff_strater
hard to say without more information, but if you are doing a "To Object" Extrude, you may just need to select "To Adjacent Faces".  This setting allows the Extrude to terminate to faces which are adjacent to the one selected
Jeff Strater
Engineering Director
mango.freund
do "split body" and "keep tool" cutting line is your sketch. greetings mango
