This will work with connected profiles and rails and is best done in the Patch workspace.
The profiles need to be at least tangent continuous and also precisely touch the rails.
You will need to eliminate the very small straight sections at the bottom of your profiles and connect the end of these profiles directly to the keel rail. If you need a small flat area at the bottom, then trim it of later.
You already have a keel rail.
Now you'll also need a gunwale rail.
Your Razma Sketch would be a top view of that Rail.
So, create a new sketch on the top plane and make sure 3D sketch is checked in the sketch palette.
Elect Sketch->Project/Include->Include 3d Geometry and project the end points of the profiles into that sketch. Then connect these points with a spline.
You'll see that in the top view it will almost precisely match the Razma sketch, so no adjustments are necessary.
Then you can create the loft. Mirror, stitch patch, stitch and you;'ll end up with a nice shape.
After I modified your file there are now a few yellow sketches in the file, but you hopefully can see the general workflow.
I congratulate you on not using too many spline control points. That's how it's done!
