HOW TO ENABLE SKETCH DESIGN IN DRAFTING TAB
atdemo2019
Message 1 of 12
atdemo2019
HI AUTODESK, I HAVE A SKETCH FILE THAT CONTAINS THE ORIGIN POINT, SO I SAVED IT SEPERATELY.
NOW I WANT TO IMPORT THAT ORIGIN FILE INTO THE WORKING MODEL. IT WORKS FINE.
I WANT TO SHOW THE ORIGIN POINT IN THE DRAFTING PAGE, BUT I CANT ABLE TO SWITCH THE IMPORTED SKETCH IN THE DRAFTING PAGE.IS IT POSSIBLE TO DO IT?
HERE I ATTACHED THE IMAGE AND FILE FYR.........THANKS IN ADVANCE
Replies (11)
Message 2 of 12
g-andresen
Break Link
günther
Message 3 of 12
atdemo2019
thanks for the input, but it is not working
Message 4 of 12
atdemo2019
i have attached the fusion file here.......
Message 5 of 12
John_Wright
Hi
3D sketches are not supported as visible in drawings. You will need to use a different approach.
John
Message 6 of 12
atdemo2019
Thanks for the input @John_Wright , I am gonna look for other ways. But the curves are visible in other softwares.
Message 7 of 12
atdemo2019
Thanks for the reply, I am using Fusion software.
I've attached the fusion file & the image for the reference.
Message 8 of 12
g-andresen
1. As @John_Wright has already mentioned, 3D sketches cannot be created in the drawing.
2. what is your intention with these sketches?
günther
Message 9 of 12
John_Wright
No disrespect intended, at all, but I do not believe that using a sketch generated in the drawing environment is what the OP wants to achieve.
Sketches in the drawing enviroment are  "dimensionally unstable"; "unlocked to geometry" and "non-parametric" that I personally believe that they should be avoided like the plague.
Message 10 of 12
atdemo2019
hi @g-andresen , I am going to do perform 3+2 machining, Due to some limitations we created a standard wcs for same kind of components. I use those curves as an origin points (wcs). those curve are represents tool shape. So the operator knows the origin point clearly.
Message 11 of 12
John_Wright
Hi @atdemo2019
I would model them as solids. I have done this in the past using round arrow shapes to indicate origins etc.
Cheers,
John
Message 12 of 12
atdemo2019
HI @John_Wright , THANKS FOR THE INPUT.
