How to edit hole thread
Hi-
Sorry for the dumb question, but how do I edit the properties of this thread? I tried right clicking on the thread once selected to bring up the hole dialog. I was able to get the dialog opened somehow but once I changed the thread size the OK button was grayed out.
Thanks, j
TheCADWhisperer
That is not the dialog image that you attached? Can you File>Export and then Attach the *.f3d file here that exhibits this behavior?
hi-
I basically have no idea what I am doing. If anyone could provided step by step that would be great.
thanks
i think i got this dialog open by going to create->hole. then selecting the threaded hole. not sure if this is referencing a new hole or the one in my cylinder. thanks.
TheCADWhisperer
Right click on the Hole feature in the Timeline and select Edit Feature.
You can now make whatever changes you need.
chrisplyler
If you started the Hole tool again, you're creating a new hole. If you Edit Feature from the timeline, as @TheCADWhisperer said, you're working on the existing hole.
Couldn't be easier, too bad I couldn't figure that out myself. Thank you.
