I am preparing a fusion model for laser cutting, and have encountered an annoyance while adjusting the cut layout for laser kerf. My process is the following. I've copied all of the bodies that I'd like to cut and aligned them to a common plane, then projected their faces into a new 'cut layout' sketch. I've then used the offset tool to expand all of the boundaries of the projected faces appropriately for the laser kerf. The issue is that if I now export this sketch to dxf for cutting, it contains both the original face boundaries and the kerf-adjusted ones. The original boundaries can just be removed in illustrator, but I'd prefer to find a way to export only what needs to be cut.
I have tried to make another new sketch and just project into it the kerf-adjusted boundaries. This is fine, except tedious. For some reason, if I select a line segment in an offset boundary and double-click it does not automatically select all of the connected segments as I expected it would. I need to project each segment individually, which is significant as my parts have finger joints with many notches.
Is this behavior a bug, and does anybody know a work-around? Or, is there a different method to export only part of a sketch to dxf?
Thanks!
