how to drawing wave washer
I'm a new user at fusion 360.
I want to draw 3 waves washer with outer diameter φ25, inner diameter φ19 and I don't know how to create the waves(picture below)
Can somebody tell me how to solving that problem?
Thank You
Elvira
davebYYPCU
Sketch the wave shape, and donut
Surface> Extrude the wave,
then Solid > Extrude > Intersect the donut.
Thicken the washer.
Might help....
how can I draw 3 waves ?
davebYYPCU
Make one, copy twice and move them to where you want them.
I am not totally sure what part is not working.
Might help...
laughingcreek
The attached should be pretty close to what you want.  I made the number of wave parametric, so you can change it via the change parameters dialog box.  you have to fix the final combine if you change the number of waves.
laughingcreek
some pics of above model-
num of waves parameter changed to 7-
