Just doing some Spring cleaning and I wanted to remove this from the All Projects filter view
Hi, Thanks for using Fusion 360.
I am not sure why you wanted to delete the Default project because you can always change the filter to created by Me or something that suits your need.
And still, if you want to delete the project, here is the easy way to do it (if you are the admin of the Team):
1. Open the web interface of Fusion by clicking on Open in Web on Project.
2. Click for Admin in the Profile dialog (as shown below).
3. Click for Projects in the Lens bar and check all the list of Projects.
4. Select "default Project" or any Project you wanted to delete and choose Archive first.
5. Once it is Archived, you wont be seeing it in the Filter list.
6. You can also Delete the Project once it is archived, but note that if the project is Deleted once it cant be restored. so i would suggest leaving it archived.
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Sasi
I appreciate the answer, but this is needlessly cumbersome. Just put an archive button right in Fusion if the current user has admin privileges.
