How to delete an individual face in a component?
gregtY4TTY
Message 1 of 9
gregtY4TTY
i have created a component, and need to delete a face, but it says you cannot delete individual faces. Is there any way you can do this?
Thankyou
Replies (8)
Message 2 of 9
davebYYPCU
Select face,
press Delete.
You will need to tell us why this does not work, linked component?
Message 3 of 9
gregtY4TTY
This is what comes up every time:
Message 4 of 9
davebYYPCU
Sorry I can't zoom in on that pic, and certainly cant read it.
Message 5 of 9
gregtY4TTY
Sorry that is quite small. Here is a better image:
Message 6 of 9
davebYYPCU
Is the body in a linked component - would explain it.
Is it a surface body?
Which face is to be deleted?
Better guesses are done when the file is checked out.
File > Export, and attach to another message.
Message 7 of 9
gregtY4TTY
No it is not a linked component, and it is a solid body. Would it help to have it as a surface body?
It is the face on the bottom that is to be deleted.
here is the file:
Message 8 of 9
gregtY4TTY
 converted it to a surface body via the unstitch tool, than made the faces i wanted another solid body. this seems to have worked. thank you anyway for your help.
Message 9 of 9
g-andresen
It is that what you want to achieve?
Register "Surface" : > select > delete
günther
