How to cut void text into object - Would appreciate any help
I'm trying to cut some text into this model and can't figure out how to. When I extrude the text it does not cut into the object shape. Any ideas? I am brand new to Fusion.  the mountain model is a stl file I downloaded. Thanks!
TrippyLighting
That contain is a mesh object and if you must use Fusion 360 for this (instead of Autodesk Meshmixer for example) it will have to be converted.
Ok thank you. Do you recommend using Meshmixer, or converting it for Fusion?
