How to cut spiral groove/slot in cylinder?
barkster
barkster
I am trying to draw this part up in fusion but I cannot figure out how to achieve it.  I swept a path along the cylinder with a twist which is pretty close to what I want but now I can't figure out how to cut the groove.  Any help would be appreciated.
TB29upIaKJ8puFjy1XbXXagqVXa_!!738665313 (1).jpgScreenshot 2021-12-28 144907.jpg
Replies (9)
laughingcreek
here's 1 approach
barkster
Thanks for the response, the only thing I see is the slot has some weird geometry that isn't perpendicular to the cylinder. I like your approach, I never use the thicken tool.  The only way I have seen someone do it was using sheet metal and the rolling into cylinder but that just seems like a ton of work.
barkster
Here is how I did it with sheet metal but I don't like this way but I think the geometry is corret.
TheCADWhisperer
barkster
thanks I had watched your video to learn how to do it with sheet metal.  I guess that's the only way to go for correct geometry.
TheCADWhisperer
Autodesk Inventor Professional - Solid Sweep Cut or Cam Design Accelerator are other options.
KristianLaholm
Too me the geometry in your files doesn't look correct,
I think if you where following TheCADWhisperer's excellent video you need to watch the video again.
The workflow from laughingcreek works if you need a "straight" helix cam-slot.
The faces of the slot must be parallell for the pin to slide freely.
In the file attached I followed the workflow from laughingcreek and added a TestPin.
You can drive the Pin joint to different positions and check the geometry with Inspect -> Interference and Inspect -> Section Analysis.
mango.freund
hello, take a look.  greetings mango
barkster
I had asked this guy that I follow on youtube how to do this and this was his response.  https://www.youtube.com/watch?v=rvL005L1xDc&ab_channel=Fusion360School
