How to create slanted faces
How can I make primitive boxes have a slant, like the image below, where the corners are kind of leading to the center and the back sticks out a little
jeff_strater
I think this is close to what you want:
Start with a sketch rectangle:
Use Extrude to get the box shape, but use Taper Angle to get the angle on the side faces:
Then, use Fillet around the top edge:
And put a big radius on the Fillet:
This will blend away the entire side faces, and get pretty close to the shape you show in the picture.  You can vary the size, height, taper angle and fillet radius to adjust the final results:
Hope this points you in the right direction.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Thank you for the answer! I was staring at this one for an hour trying to figure out how to cut that edge away instead of just tapering the extrusion.
