How to create body where the bottom is scaled vs. the top ? (with picture)
ittay.dror
ittay.dror
Basically, I want to create something along the lines of the following image:
The top is scaled down vs. the bottom in one axis. (I did the above in Sketchup by pulling the base and then moving the point at the top)
etfrench
Use dimensions and user parameters.  You can enter formulas which relate the sizes in either of these.
ETFrench
jeff_strater
I would do this as a loft, with two sketches.  You can use parameters, as @etfrench suggests, for precise control
Jeff
Jeff Strater
Engineering Director
