How to create and subdivide circle plane?
travis.designer.vn
Message 1 of 16
travis.designer.vn
Hi
I try to create and subdivide circle plane in Form Mode:
How can I make it?
Best regards
Travis
Accepted solutions (3)
Replies (15)
Message 2 of 16
laughingcreek
what are you trying to end up with? do you have a drawing, sketch, picture of something like what you want?
Message 3 of 16
travis.designer.vn
Hi laughingcreek;
I try to replicate this model:
I intent to create circle plane, then subdivide. I will move vertex. This is first brainstorm.
Message 5 of 16
travis.designer.vn
Thank laughingcreek, I will consider it and give feedback asap
Message 6 of 16
laughingcreek
another approach if you don't want a regular pattern.
Message 7 of 16
travis.designer.vn
Thank laughingcreek ,
I think this is good solution in this case.
Message 8 of 16
travis.designer.vn
After 5 hours, This is result 😀
Message 9 of 16
chrisplyler
You certainly CAN do it with a Form. If you're looking for parametric control and geometric regularity, I certainly prefer to model it WITHOUT a Form if possible, using the typical Solid and Surface tools based on Sketches.
https://knowledge.autodesk.com/community/screencast/3c51d4f0-034f-45b1-8282-50a9bb8b161c
Message 10 of 16
laughingcreek
That's more or less what we did.  my sketching was'n't as sophisticated because it was late, and I didn't feel like fiddling with it.
Message 11 of 16
chrisplyler
And, yes, I can also control variance in the waves' frequency...
Message 12 of 16
chrisplyler
Ah... I thought you guys were working with a Form. Sorry to stick my nose in then.
Message 13 of 16
laughingcreek
actually, the OP might benefit from studying your sketch.  Mine was really a hack job, just to illustrate a possibility.
Message 14 of 16
travis.designer.vn
Great Job chrisplyler, I intent to try build this model in Form model.
Could you please share the file. Thank
Message 15 of 16
chrisplyler
Here you go...
Message 16 of 16
travis.designer.vn
Thank chrisplyler
