How to Create an interupted Chamfer?
Inspections_JCH
Inspections_JCH
My design has a need for a chamfer of limited length. I call it a relief cut. While I work on this project, there may be a need to modify this feature, so I would like it to be auditable and easily edited. My first attempt was done by using a second body as a tool to cut away the chamfer. But I do not know how to audit and then edit that feature easily in the future.
For this demo I created a component and then the ends were two additional components. Was that the only solution?
I made this file to allow everyone to see what it is, but even this example file was a challenge when I knew that I wanted to change the appearance  of the chamfered area to a different color from the two ends. So this is a second question: Can I apply a material to only one face for presentation purposes?
jeff_strater
This is not really a chamfer, in my mind.  It is more of a Face Draft.  I did this a couple of ways.  You can split the body, or you can split the faces.  I think I prefer the split faces approach, because it leaves you with just one body.  And yes, you can apply color to only some faces.  I did not take the time to apply it to all faces, but with more split faces, you can do that.
Jeff Strater
Engineering Director
g-andresen
hi,
try this
günther
jeff_strater
you seem to have figured this out already, in this other thread:  angle-between-sketched-lines-on-a-design
Jeff Strater
Inspections_JCH
I comprehend the split face method very well. Thanks!
Inspections_JCH
Thanks @g-andresen This is just what I had in mind, but I struggled sketching the lines. This screencast was very instructive.
