how to create an assembly between roller and a box in a conveyer roller
binkalsharma0001
binkalsharma0001
Hello there, I am new to fusion 360 and trying to create a roller conveyer with a tank on it. But I am stuck with the assembly of it. could you please help me create an assembly between roller and a box in a conveyer roller so that the tank moves along the conveyer, just as a tank would move on a conveyer rollers. Also, how can I make a simulation out of it? I have shared a link to the file, please help me with this. I would really appreciate your help.
Link to the model file
Drewpan
I have had a quick look at your model and there are a few issues I can see that probably should be fixed.
It appears that you have manually placed all of your rollers and some of them look a bit strange with the spacing
and there are a number of interfering components. A circular pattern may have been a better solution to get the
spacing a little more even.
You already have an assembly. The Inner and Outer Frames and the Rollers create the assembly within the top
component.
It isn't exactly clear what you want but I think you want to animate the Tank rolling around the assembly on the
rollers. I am not sure this is possible to do automagically, you might have to animate it by hand in a stop motion
style in the animation work environment. There is nothing that will drive the tank around like gears or such. What
makes the Tank move? Are one or more of the rollers driven by something?
What do you want to simulate? Animation will make it move. Simulation will calculate stresses and strains.
What is it you actually want us to do?
Cheers
Andrew
binkalsharma0001
thank you for your quick response. I want the tank to move when clicked and
dragged. It would be great if you could tell how can I do it.
TrippyLighting
Before moving on to more complex assembly operations, my recommendation would be to learn proper modeling and assembly techniques. However, below is a video explaining how to achieve what you are asking for:
binkalsharma0001
Thank you so much for your help and suggestion. I will work on your recommendations.
