I am new to Fusion and have a problem using prejected lines for creating a loft:
I want to cut through the half-cylinder. So I projected the left rectangle to the cylinder, which gives the pink lines. Now I want to create a loft from the backside blue rectangle to the pink lines. But that does not work. I cannot select the projected lines as starting or end points of the loft. I can do a loft from the left blue rectangle to the right blue rectangle which is slightly smaller. But then the upper and lower edges from the cutout are not parallel to the cylinders upper and lower edges. Therefore I did the projection.
Any hints how I can do that?
Thorsten
