How to create a diogonal sheet between two edges
autodesk
autodesk
probably very simpel, but I am completely new to Fusion 360.
I am creating a ponton (floating chamber) I made a model once in C4D, so I have a 3d Picture for you here: Ponton 3D.png
(cm should be mm 😉
I got that far in Fusion 360: Bildschirmfoto 2018-01-05 um 17.49.45.png
Now I just cant get the diagonal sheets in the body. Also all the edges should be bent at 90° for stabilisation (see first picture)
The Ponton will be made with 2mm Aluminium-sheets. So all thicknesses are 2mm.
Can anybody help me with this?
Hansen
HughesTooling
The web tool will do what you want. See screencast. I deleted the form from the timeline as it didn't seem to be doing anything then drag the sketch after the shell and added crossing lines.
Mark
Mark Hughes
Owner, Hughes Tooling
autodesk
Awesome! Tanks for the ultra fast Reply 🙂 Wohoo!
